Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Feb 2015
    Jalil Smith
    94 Z28 Camaro
    Humble, Texas
    Default Stock bottom end build
    Well as fate had it I cracked the block when my cam broke so now I'm considering dropping in a stock block. It has 42k original miles on it out of a Vette so already a 4 bolt main. I guess I'm just more concerned about it living with a little over 400rwhp and about a 150 shot. Should I go ARP rod bolts or just leave everything as is?
    Sent from my XT1585 using Tapatalk
    Quote Originally Posted by Z28_Jay View Post
    Let it eat
    Feb 2015
    Jalil Smith
    94 Z28 Camaro
    Humble, Texas
    Let it eat
    My thoughts exactly just wanted some input I'll be picking it up Wednesday and just throwing my heads cam and intake on before I drop it in best thing about this is I only paid 400 for the complete motor fuel rail covers accessories and all
  4. The Following User Says Thank You to Z28_Jay For This Post:
  5. #4
    Feb 2015
    Jalil Smith
    94 Z28 Camaro
    Humble, Texas
    Think it would like being shifted at 6600? 😎
  6. #5
    If it looks good inside let it eat. I'm all about budget. Just rebuilt mine for less than 200 bux.
  7. #6
    Feb 2015
    Jalil Smith
    94 Z28 Camaro
    Humble, Texas
    I'll definitely inspect everything before I drop it in I have to swap the pan anyway just a little piece of mind before I go beating on it.
  8. The Following User Says Thank You to Z28_Jay For This Post:
  9. #7
    Feb 2015
    Jalil Smith
    94 Z28 Camaro
    Humble, Texas
    Stock cubes? I need to do what you did lol
  10. #8
    Polish stock crank, mahle stock replacement rings and king stock replacement bearings. Block quick ball honed. New cam bearings.
  11. #9
    Feb 2015
    Jalil Smith
    94 Z28 Camaro
    Humble, Texas
    Not a bad deal, I'll give it some time I might just go forged rods and pistons before I put it all together just for security if I want to up the shot a bit. Not sure if I want to use this cc306 I have or switch to the Lunati 231/239 grind I've had my eye on.
  12. The Following User Says Thank You to Z28_Jay For This Post:
  13. #10
    Mar 2010
    Sean Foster
    1995 Trans Am
    Barboursville WV
    I'd be more concerned about the pistons than the rod bolts.
    If it gets you up and going and your fine with the chance that it might not live to long let it eat.
    Sean Foster
    383 AI 200cc/custom grind w/full bolton's. 4L80E w/edge 3600 stall, Moser 12 bolt w/4.10 A/C & Hitch= true street
  14. The Following 2 Users Say Thank You to 1sickta For This Post:
