Results 1 to 2 of 2
Yesterday, 04:42 PM #1
- Feb 2025
- Kurt Esposito
- 1994 Corvette
- 1
Engine won't crank over with a single plug in it
Have a rebuilt 1994 350 LT1 Vin P. I was just supposed to be installing it. When we try to crank it over it will spin free with no plugs in it but if I put a single plug in any cylinder it stops on that cylinder's compression stroke (?).
I have been told by an engine rebuilder that the timing should be set at cylinder 6 tdc, however the person that rebuilt it believes he set it at cylinder 1 tdc.
My 2 questions are:
1) Is it possible a cam being off 180 degrees would cause this
2) I want to rotate the cam 180 degrees but am unsure if this is an interference engine.
Thanks in advance
Kurt
Today, 08:59 AM #2Xtreme Member
- Nov 2008
- Chris
- 1994 Trans Am
- PA, USA
- 2,450
Are you sure it's not a weak battery?
The Following User Says Thank You to harner For This Post:
