Results 1,181 to 1,190 of 1209
Thread: Project Rainbow Unicorn 2013
01-06-2025, 06:05 PM #1181
Mounted top of radiator
01-06-2025, 06:11 PM #1182Administrator
- 7,458
01-06-2025, 06:45 PM #1183
I will be relacing em with nutcerts but, this is a proof of concept.
01-19-2025, 07:24 AM #1184
Big photo dump from the past week or so
Had to modify the radiator to get room for the air filter on turbo. Also added vac line port to elbow.
No more coil of copper, proper backpressure damper cylinder
Painful purchase but MLS gaskets are the best
While I was waiting for heads, have been experimenting with manifold heat management
01-19-2025, 07:27 AM #1185
And the heads, machine shop found some lovely gems from the previous owner of these heads
But both heads resurfaced, 0.007 off both to clean up
Its hard to see but the bolt/head stud holes were reamed out, and then sleeved so the port breakthru didn't suck oil down from top of head
Pretty sure every LT1 owner goes thru this picture at least once
Heads on, rockers & guides setup, intake bolted down
01-19-2025, 09:36 AM #1186
Looks great. You've been busy. Is the intake actually touching the cowl or optical illusion?
01-19-2025, 09:38 AM #1187Administrator
- 7,458
01-19-2025, 06:07 PM #1188
No cutting needed
01-19-2025, 07:51 PM #1189Administrator
- 7,458
01-19-2025, 07:59 PM #1190
I don't even have the hotside on yet lol
