Results 241 to 250 of 258
08-18-2018, 04:36 PM #241Xtreme Member
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,926
Some recent pics0818181530_HDR_Film1-1.jpeg0818181519_HDR_Film1.jpeg0818181520_Film1.jpeg
Sent from my VS995 using Tapatalk96 Z28 - ERE-383, AFRs, 9", Procharger D1, TermiX, etc.
08-18-2018, 05:43 PM #242Administrator
- 7,468
08-19-2018, 07:56 AM #243Xtreme Member
- Mike
- Conshohocken, PA
- 1,926
It's all in the details. Timing and fueling in line? MAP drop minimized? How many afgs relative to other setups? On the Camaro, I went from 382 to 425whp with some pretty minor mods and tuning revisions.
There was a guy who made 400whp with a LE1/cc306 setup. Hopefully 370 is attainable if my setup is well optimised.
08-19-2018, 07:58 AM #244Administrator
- 7,468
08-19-2018, 08:21 AM #245Xtreme Member
- Mike
- Conshohocken, PA
- 1,926
I know, I'm just saying that there's a lot of little factors people want to ignore because some grouch on ls1tech said those mods were a waste of time. Statements like, "I made 500whp with a stock throttle body, the stock one is fine." I stopped listening to that garbage, got a Holley 58mm, lightly ported my LT4 mani, ripped my Moroso CAI out, added 4 deg timing, leaned it out a point and bam.... +43hp. There are a lot of little details that can be overlooked and it sounds like your LE2 motor had the potential to crack 400 if there are people doing it with LE1's and a shelf cam. Wasn't that cam a LE grind in the low 230's?
08-19-2018, 08:26 AM #246Administrator
- 7,468
Supporting Membermy motor probably can make more, I have not spent any time optimizing anything. I'm lucky it runs. low 230's duration, high .5xxs lift. dyno day was shit injectors a mashed up tune and a failing opti. one day I'll actually spend the time, but once again it's just make car run so it's not a lawn ornament
I also take anyone's internet dyno talk with a grain of salt because we all know how easy it is to skew a dyno. hence why osies car has a 9" now, dyno doesn't tell us anything besides afr looks good, seeing what it does on track will be more telling.
this reminds me, I need to get more PVC for the impala's intake
Sent from my SM-N950U using TapatalkLast edited by SSlowBoat; 08-19-2018 at 08:32 AM.
08-19-2018, 09:31 AM #247Xtreme Member
- Mike
- Conshohocken, PA
- 1,926
I would just grab a 3.5" pipe and 3.5/3.25" coupler on ebay, the pvc is too small on the inside.
08-19-2018, 09:43 AM #248Administrator
- 7,468
10-11-2019, 02:48 PM #249Xtreme Member
- Mike
- Conshohocken, PA
- 1,926
I got a 4-bolt vette block in a parts deal a few years back along with some other engine goodies. It has been bored 0.030 and honed for a forged set of Probe SRS pistons, line bored with ARP studs, freeze plugs, cam bearings, etc. I went and double checked the piston/wall clearances and found I can get everything between 41-46 ten thou which is good. The pistons have a dish that's not big enough for FI or small enough for a decent NA/spray build in a 355 with my LE1's unfortunately. If I increase the stroke a little, it'll make the compression more reasonable. With 3.8", I'll have a 388ci motor with 12.1:1 on my heads. The block hasn't been decked (just cleaned up) so I will have enough material for the extra stroke over a 383.
The block came with hellfire rings and I have a XFI468 sitting on the shelf I'd like to make use of. Might make a decent spray motor. The LE1's aren't ideal in this case but I'm trying to throw this together on a tight budget and reuse the Roadmaster's top end (except valve springs, pushrods, maybe lifters, etc.).
I've been wanting to make use of this stuff for a while but honestly didn't want to put it into this car (because it's too ugly). I think ultimately the entire drivetrain will end up in an older B-body (like a 2 door 77+ Impala/Caprice) or C-body (77+ Coupe Deville) because I'm lazy and want to reuse the suspension, rear end, 6 spd parts, and other bits. The current car is gonna be the test pig though.
So the shopping list looks like:
-Scat 3.8" 4340 crank
-Scat 6" 4340 7/16" arp2000 rods
-Melling 10552
-BTR spring kit?
1010191941.jpg96 Z28 - ERE-383, AFRs, 9", Procharger D1, TermiX, etc.
10-12-2019, 11:10 AM #250
Would advise thoroughly researching hellfire rings prior to installing and using them.
