Thread: Trans swap now motor overheating
09-14-2019, 05:18 PM #1The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
So the th400 that was in my car with slip when it came time to change gears so I decided to build my very first transmission I swapped it a week ago and on the drive home everything went just fine with the transmission shifting when it needed to but now the motor slowly gets hotter and hotter almost like the thermostat is stuck open I put a new thermostat in the car and the temperature still slowly creeps up I'm at a complete loss because I did absolutely nothing to the motor and it was running just fine before hand any idea what would cause this?
Sent from my SM-N950U using Tapatalk94 Formula "budget build" #thebeaterbird
09-15-2019, 11:31 AM #2LTX Regular
- Aubrey
- (2) 1994 Camaro Z28
- Janis Joplin's neck of the woods
- 204
Maybe ya pinched or kinked the steam tube between the heads at the rear of the motor? Even a ding in such a small diameter tube worries me when I think of my upcoming tranny swap.
'94 Z28 Red, SLP Ultra Z hood/air box/spoiler, LT1 w/deletions & mods, 4L60e Pro Race build by CPT, Pacesetter LTs with stainless Speed Engineering LS1 True Duals, LS1 front brakes, Kenny Brown Double Diamond SFCs.
09-15-2019, 11:56 AM #3The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Its beed upgraded to an fittings and a steel braid hose.
09-18-2019, 09:55 PM #4"The Rock"
U still running the air damn?
LTXtech.com is my drug...
09-18-2019, 10:00 PM #5The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Of course, our cars absolutely need the air dam ... it's pretty uncommon but I wonder if the radiator is just getting worn out or if the radiator is partially full of sludge... I've driven it a few times this past two weeks. It seems like if the AIR temperatures outside are around 85 degrees and under the coolant will stay around 180 degrees and won't climb but if it's in the 90s the temperature slowly climbs up as i drive regardless of speed.
09-20-2019, 10:12 AM #6LTX Regular
- Aubrey
- 204
09-29-2019, 09:17 AM #7The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Got some factory fans and it seems to run cooler ... ill do some more test drives during the heat of the day.
