02-07-2018, 05:51 PM #1
Pros and cons of swapping from a 60e to a 400
so im really thinking about swaping over my car from a cpt pro race built 60e to a cpt 400 with a brake but i need some. pros and cons from everyone so it can make my choice a little easier.
set up
350
H/C
DANA 60 -4.10 GEAR
STALL AS IS RIGHT NOW 3600-3800
NITROUS CAR ON A PROGRESSIVE 125 SHOT
26" TIRE
02-07-2018, 06:09 PM #2
Well the brake is definitely a plus. Other than that, you lose overdrive. Unless the 400 has better gear ratios for your application.
02-07-2018, 08:16 PM #3LTx Guru
- 2,331
Upside - TH400 can be built for more power (but Cahall can build a killer 60E), easy to run a brake and a manual valve body.
Downside - heavy, larger drivetrain losses (saw over 20% drivetrain loss at 750 HP with a non-locking converter). And as mentioned above, no O/D (unless you add a heavy, expensive Gear Vendors O/D). Then there's the 2.48:1 1st Gear, vs. 3.06:1 in a 4L60E. New driveshaft required. New/modified trans cross-member
With the TH400 and 4.11 gears I was running close to 4,000 RPM at 70 MPH with street tires. The GV lowered it to a bit above 3,000 RPM.Last edited by Injuneer; 02-07-2018 at 08:18 PM.
02-08-2018, 09:10 AM #4
- Mar 2015
- Jeff Green
- 1996 Impala SS
- Fishers, Indiana
- 67
Unless you're over 1200 HP there is no good reason to go to a 400. If built right a 4L60E can take up to 1300 HP and you can put a brake on a 4L60E.
I had a Rossler 4L60E in a 4500 pound Impala and got it to a best of 9.2 at 157 MPH. There is a video on u-tube that someone took of the Impala on a test pass that shows 9.4 at 153 MPH and that was on a 4L60E with a factory ten bolt rear end and at 4500 pounds. I think you can find the video searching "Jeff Green 9.4". The video quality is bad but it shows what can be done.
In a Camero that weighs 1000 pounds less or more, you should never hurt a 4L60E if its built right. You should be able to run it into the 8's with a lighter car.
So my vote would be not to put a 400 in your car.
02-08-2018, 11:39 AM #5
- Jul 2013
- Alex Rauld
- 1994 Trans Am GT
- 226
That's an amazing testament to what the 4L60e is capable of in the proper hands.
1994 Trans Am GT - HPS Ported Heads/Intake, LE Cam, FTI 3600, TP Built 4L60e, Moser 9" w/ 3.90's, BMR Suspension, Formato Tuned
02-09-2018, 08:43 AM #6Administrator
- 7,458
Supporting Member@Cahall has built 4l60e's that go 9's and 10's all day for camaros and impalas as well.
Sent from my SM-N950U using Tapatalk1994 Firebird Formula 381 stroker - Carrying the torch! - 9.90 @ 134.3mph on a 200 shot
02-12-2018, 05:29 PM #7
THIS IS A CPT TRANS FROM FRANK. just trying to get pros and cons.
