01-05-2018, 10:47 PM #1The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
Tail light not working correctly now
Okay about 3 years ago when I was a daily driving the car the brake lights worked perfectly fine the car was parked for a couple of years for a new engine rebuild and dedicated drag racing build. So now the car is drivable again and the tail lights now are acting up everybody says to check my grounds and everything is good and tight I literally haven't changed or done anything so I don't know what's happened.
The video shows what's going on
Sent from my SM-N950U using Tapatalk94 Formula "budget build" #thebeaterbird
01-06-2018, 11:55 AM #2LTx Guru
- 2,326
Have you checked the sockets for corrosion? Seems like the bright filament for the brakes is still getting voltage without the brake pedal being pressed.
01-08-2018, 03:15 PM #3Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Yeah that was a deal with mine had to change everyone. Sockets where crap.
01-09-2018, 07:20 AM #4Lurker
- Johnny
- 1994 formula A4
- Henderson, TN
- 935
Dont buy the dorman ones, they are JUNK
01-11-2018, 01:48 PM #5The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
01-12-2018, 07:45 AM #6Lurker
- Johnny
- 1994 formula A4
- Henderson, TN
- 935
That's a good question, I got 1 from Dorman witch I am using now but had to basically destroy it to get it to fit. I wonder if the ls1 style sockets will fit?
01-12-2018, 12:11 PM #7
- Jul 2013
- 95 Firehawk
- Indiana
- 58
LS1 sockets should fit. LS tail lights are always swapped into the LT cars, so should be the same.
01-12-2018, 12:19 PM #8The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
But where can I find some good NEW pigtails/sockets for the tail lights?
01-12-2018, 01:26 PM #9Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
I got some from rock auto. Got the high dollar ones. Use heat shrink butt splices
AC Delco ones
https://www.rockauto.com/en/catalog/...ht+socket,4008
Sent from my LGLS990 using TapatalkLast edited by Stormyweather; 01-12-2018 at 01:40 PM.
The Following User Says Thank You to Stormyweather For This Post:
01-13-2018, 05:33 PM #10The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
So turns out the bulbs were in backwards.... no idea how that happened but fixed now
The Following User Says Thank You to zooguy For This Post:
