Thread: Double roller timing chain
09-23-2017, 04:07 PM #1
- Jan 2012
- 39
Will a double roller timing chain clear the stock cover ? I am running a electric water pump .
09-23-2017, 05:14 PM #2The FABRICATOR!
- Jul 2011
- 1985 Monte Carlo SS
- southern illinois
- 7,164
Most will. Best thing to do is bolt the cover on without a gasket and rotate the engine around 2 revolutions. Take the cover off and check for marks on it. If it will clear without a gasket you're good.
The Following 2 Users Say Thank You to firebird_1995 For This Post:
09-23-2017, 06:08 PM #3
- Jan 2012
- 39
Ok , thanks for the help
10-06-2017, 06:31 AM #4
- Oct 2013
- Evansville, IN
- 143
I'm running a Cloys double roller on mine.... I had to clearance the cover.... not a big deal at all
96 Vert 383 forged AFR 210 LT4 Intake CP Pistons T400 Moser 9" Borg Warner S480
10-06-2017, 10:05 AM #5Administrator
- 7,439
Supporting Memberusually have to grind the cover, not a big deal, but a solid single roller clears without any mods
Sent from my SAMSUNG-SM-G935A using Tapatalk2021 Charger Scat 392
