    Jan 2017
    Marshall
    1987 firebird trans am
    Default 1987 trans am lt1 swap
    So I got this trans am a while back it had an lt1 out of a 95 z28 swapped into it i want to begin building it I want to start with intake and exhaust but I'm wondering what issues I'll run into with everything lining up right
    Sent from my SM-S320VL using Tapatalk
    U stated the motor was already installed, right? So what do u mean by "line up."
    OWNER/ADMIN
  3. The Following User Says Thank You to popo8 For This Post:
  4. #3
    Quote Originally Posted by Fuzzy21 View Post
    Waht?
  5. #4
    Jan 2017
    Marshall
    I mean I want to put long tube headers and a different exhaust system I know nothing about cars I guess I'm asking does the motor being in a different car affect what I can do to it since there is space differences
  6. #5
    Not really because its physically a small block chevy, which also came in the 3rd gens.
    OWNER/ADMIN
  7. #6
    Longtubes for a third generation will bolt up. Just get ones for fastburn heads
  8. #7
    LTXTech Sponsor
    Feb 2009
    David
    1985 Camaro Z28/1994 Firebird Formula
    MO
    For the headers and exhaust buy a set that fits the car with a standard small block chevy. If you are going 1 5/8" or smaller primaries then you will want to get a D-port header. If you are going with 1 3/4" primaries then the normal round tube will usually seal up just fine.
    -David-
    1985 Camaro Z28 (Under Construction)
    1994 Firebird Formula - LT1/4L60e (The Daily)
