    The FABRICATOR!
    southern illinois
    Default 24x setup with ati bbc snout damper
    Efi connection 24x setup with crank sensor...
    https://www.eficonnection.com/home/p...t-w-ckp-sensor
    Image: https://uploads.tapatalk-cdn.com/2016...161a078b3d.jpg
    Sold
    ATI super damperwith hub for 2.25" seal.
    96+ timing cover machined for larger seal
    Image: https://uploads.tapatalk-cdn.com/2016...1ab17ce8a9.jpg Image: https://uploads.tapatalk-cdn.com/2016...57a6db92e2.jpg
    sold
    96+ timing cover
    Image: https://uploads.tapatalk-cdn.com/2016...732b99830e.jpg
    $75 shipped
    Misc ls coils and bracketsImage: https://uploads.tapatalk-cdn.com/2016...e3194030f1.jpg
    $75
    The FABRICATOR!
    southern illinois
    Bump
    Whats the part# on the ATI? Its been a while since I have done any research on the 24x but am getting back on track for my project. Is it double keyed? I need one that is double keyed. Does this work on the LT1 crank being that it is a BBC snout? If the ATI works for my application, I would want to work out a deal on everything listed. Im building a F1R Procharged 383 LT1 with double keyed Callies crank. The shortblock is done, I only lack the 24x setup and damper to assemble the engine.
    @firebird_1995
    From my quick research it looks like you have what I need. Im hoping the hub is double keyed. I would be interested in the 24x setup, damper, hub, machined timing/cam cover.
    The FABRICATOR!
    southern illinois
    Here is the damper and hub. It is for a standard sbc nose but for a 2.25" seal.
    https://m.summitracing.com/parts/ati-917270
    https://m.summitracing.com/parts/ati-916048b
    Paypal sent for 24x, damper, hub and cover. Thanks
    The FABRICATOR!
    southern illinois
    Received!
    Updated thread
    10 Second N/A Club
    Josh
    96 Z28
    Holden, MO (KC)
    Any info on the LS coils, came from??? I'll need some this winter for my CNP upgrade but and I've heard "get truck coils" etc but I have no idea if any one is better than another. I was told the truck coils have heat sinks on them.?.?
    -Josh
    co-owner of BDBRacing.com
    NMCA OC 9004
    The FABRICATOR!
    southern illinois
    Quote Originally Posted by 96LT1355Z28 View Post
    About the only thing I know on them is they are the non heat sink coils and there are 10 good ones in that pile. 2 have the spark plug tower broke. The rest is all jibber jabber to me because I never took the time to learn more about 24x. I think that the aluminum brackets in the picture are for the heat sink style coils. If you are interested in this pile I'd do it for 65 shipped.
  10. #10
    10 Second N/A Club
    Josh
    96 Z28
    Holden, MO (KC)
    I'll do some researching and get back with you.
    -Josh
    NMCA OC 9004
  11. The Following User Says Thank You to 96LT1355Z28 For This Post:
