Results 1 to 4 of 4
Thread: EGR Problem
07-30-2016, 12:38 PM #1LTX Master
- Jun 2013
- Beaver
- 1994 camaro Z28
- KENTUCKY
- 602
EGR Problem
I had my EGR deleted on my PCM.The check engine light was on.So we ran a scan on it.It came up with all kinds of EGR codes.If my EGR was deleted,shouldnt it not even show up.Little along have problems??
BEAVER
07-30-2016, 02:29 PM #2LTx Guru
- 2,326
Which codes? There are only two codes for EGR - DTC 27 for faulty electrical circuit on the EGR vacuum solenoid, DTC 32 for EGR flow, measured by cycling the solenoid and looking for a change in MAP to show the EGR flow. Can't speak to the tune, I gave up on the stock PCM 16 years ago.
07-30-2016, 04:30 PM #3
- 1996 Z28
- Newark, DE
- 106
If the codes were deleted in the PCM, then they should not show up at all or be triggered. Might have to send it back to the tuner.
07-30-2016, 05:27 PM #4Xtreme Member
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,924
Who is your tuner? Sounds like someone forgot those egr codes
Sent from my VS986 using Tapatalk96Z M6, ERE-383 #60, AFR 210s, LE cam, 9", Procharger D1, ???whp
