Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: AFR 227 Heads
  1. #21
    Mike
    96 Z28, 95 Roadmaster
    Conshohocken, PA
    Is it because the 227s have 60/40 valve spacing?
    Sent from my VS986 using Tapatalk
  2. #22
    I have them.
    I want to know what pistons he is running that the 227s wont work.
    OWNER/ADMIN
  3. #23
    You need pistons with 60/40 valve spacing to work properly. You can get away with regular pistons if you aren't running a big cam, but put a big cam over 250 degrees with a shallow lsa and the valves will hit because the reliefs in the piston tops aren't aligned.
  4. The Following User Says Thank You to joelster For This Post:
  5. #24
    Quote Originally Posted by joelster View Post
    Ok... i remember something like that when we put mine together. But i had enough clearance with the rotating assembly we chose.
    OWNER/ADMIN
