Results 1 to 3 of 3
    The Nitrous Outlet Junkie
    Apr 2010
    Troy
    1994 Firebird Formula
    moore, ok (south okc)
    Default Help with a camshaft
    Okay so I bought this camshaft a while back from somebody on the site and I was wanting to know if I could get a little bit of help with some information I'm not sure about. I was wanting some help maybe getting what is usable power range is. and a little bit of clarification on the LSA I'm not sure.
    This was the cam card that was included
    Sent from my SM-N910T using Tapatalk
    LTXTech Sponsor
    Sep 2010
    Red Oak Tx
    on stock heads it will have an RPM range of around 2200-6300 RPM.
    Wirth ported heads it can pull a cpl hundred RPM higher.
    Nild enough for 3.23/3.42 gears but more gear will always make the car a lil quicker.
    If auto a 2800 stall would be suggested but a higher stall will always make the car launch better.
    Use a good dbl spring with 145-155 lbs on seat and 350+lbs open pressure.
    Lloyd
    With a 1.6 rocker valve lift will be .564", the lift that the card shows is with 1.5's. The cam seems a touch hotter than a CC503. It's a 226/234 on a 111.
