07-29-2015, 03:56 PM #1Lurker
- Dec 2012
- Brad Powell
- 1994 Camaro Z28 M6, LT4
- Lexington, KY
- 34
what solid lifter for push rod length checking?
I got the LE2 h/c/i treatment and just got around to buying Ultra Pro Mag 1.6 rr's. I need to figure my push rod length and I was wanting to do the solid lifter method, since my intake is off and my heads are already assembled. The lunati lifters I have in the engine have a 2.66" seat height. I can't find a solid lifter anywhere that is the same. Should I just use any solid lifter and subtract the difference in seat height between the two and just add that distance to the pushrod length? This has been bugging me all day at work. I searched on forums and google and couldn't find what solid lifter works.
2007 Silverado CC Z71 VortecMax
1994 Camaro M6 Z28. 355 forged 24x LE2 LT4 H/I, LE cam, supporting mods, LT's ypipe, etc
07-29-2015, 04:05 PM #2InActive Member
- Oct 2008
- Jim
- 1996 Z28
- Sugar Grove IL
- 1,243
Take a hyd lifter, gut it and fill with washers put back together and make your own solid lifter.
1996 camaro Z28, Clayton racing 398, Rossler TH350 rmvb with brake, FTI billet race converter 4400, Dana S60 with 4.10's, 300 shot, Accel DFI controlled, UMI, Spohn, PA racing, QA1's, Baer brakes, 325/45/17 M&H, Caged, Corbeau's, Simpson, etc.
From zero to fuck yeah in 3 seconds.
The Following User Says Thank You to JPack For This Post:
07-29-2015, 05:21 PM #3Lurker
- Dec 2012
- Brad Powell
- Lexington, KY
- 34
I don't have any extras, guess I'll have to go buy one
Sent from my iPhone using Tapatalk2007 Silverado CC Z71 VortecMax
07-29-2015, 05:58 PM #4
Use a $15 set of checking springs, instead of your regular valve springs. They won't have enough pressure to depress any regular hydraulic lifter. They have about as much pressure as the spring in a ballpoint pen.
The Following User Says Thank You to joelster For This Post:
07-30-2015, 08:21 AM #5Lurker
- Dec 2012
- Brad Powell
- Lexington, KY
- 34
07-30-2015, 09:05 AM #6
I have a bag of garbage LS7 lifters if you would like one to gut and use as a solid let me know.
07-31-2015, 10:46 AM #7InActive Member
- Nov 2014
- Walter Devine
- 1996 Z28 2002 Z28
- Rowletts, Kentucky
- 341
I have some as well if you want to drive 2 hours to pick one up, I located in Munfordville KY
96 Z28 LT1 stroker, cage 9 inch, spray 10.24@134.58 1.54 60
02 Z28 edge converter, LTs, lid, cam, spray 12.0@112N/A
08-01-2015, 11:31 AM #8
LTXTech Sponsor
- Sep 2010
- Red Oak Tx
- 541
Just make sure the "solid" lifter that you use has the pushrod cup at the same ht as the actual lifter that you are going to run.
Lloyd
08-03-2015, 03:45 PM #9
Proform make a PR check tool for around $12 that is very simple to use. I have compared results with the old PR length tool and this and same results. You do not need a solid lifter or soft spring to use it. Very plug & play. Just a feeler gauge to measure, if any, the distance between tool and valve tip to +/- a PR length
they come in 3/8 & 7/16 size
http://www.summitracing.com/parts/pr...FQuQaQodanMC4Q96 BBB 383/T56
08-04-2015, 08:37 PM #10Lurker
- Dec 2012
- Brad Powell
- Lexington, KY
- 34
