    Nov 2014
    Walter Devine
    1996 Z28 2002 Z28
    Rowletts, Kentucky
    Default Here is the sign at Beech Bend
    I only seen this 1 right by the gate when you come in. I was going to walk around and look for the other one but it came a flood about 20 minutes after we got there and they called it off.
    96 Z28 LT1 stroker, cage 9 inch, spray 10.24@134.58 1.54 60
    02 Z28 edge converter, LTs, lid, cam, spray 12.0@112N/A
  2. The Following 6 Users Say Thank You to waltsfastz For This Post:
  3. #2
    LTXTech Sponsor
    Feb 2009
    Brad
    1979 Monte Carlo
    Moscow Mills, MO
    Blog Entries
    1
    Thank you sir, its good to see that it is still up with all of the banner thieves out there these days. Hopefully all of the local LTXers that are not on here see it and come out to play this year, something that has been missing the past few years.
    2013 King of Street & ES/PA Champ
    1979 Chevy Monte Carlo 383,Stock Ported Heads, 4L80 with Edge converter, QP 9", Nitrous Outlet Plate Kit
    Certified Performance & Auto Repair Inc.
  4. The Following User Says Thank You to 79LT1Monte For This Post:
  5. #3
    Nov 2014
    Walter Devine
    1996 Z28 2002 Z28
    Rowletts, Kentucky
    Honestly I didnt even look for it coming in, it just cought my eye
  6. The Following User Says Thank You to waltsfastz For This Post:
  7. #4
    LTXTech Sponsor
    Feb 2009
    Brad
    1979 Monte Carlo
    Moscow Mills, MO
    Blog Entries
    1
    Quote Originally Posted by waltsfastz View Post
    That's even better!
  8. #5
    The FABRICATOR!
    southern illinois
    That's great. Exactly what we need!
  9. #6
    Dec 2010
    Daniel
    1995 Camaro Z28
    Mount Juliet, TN
    give me a shout next time you head out there and Ill try and make it. Im east of nashville about 30 minutes, it takes me about hour and a half to get out to beech bend.
    95 z28- 6spd, edelbrock headers, k & n fipk, flowmaster exhaust 2othl, 160 thermostat, hypertech programmer, 182k miles and counting.
    05 dodge ram rumble bee #1511- pretty much exactly the same bolt ons w/way less miles on it.
  10. The Following User Says Thank You to doferrell For This Post:
  11. #7
    Nov 2014
    Walter Devine
    1996 Z28 2002 Z28
    Rowletts, Kentucky
    Quote Originally Posted by doferrell View Post
    Will do, I hope to be going more often when i get my 96 car finished, But I may take my LS car back out this month sometime
  12. #8
    Dec 2010
    Daniel
    1995 Camaro Z28
    Mount Juliet, TN
    Sounds good, I can only watch right now. My car started sputtering when it gets past 5k rpms, and my truck needs tires before i can take it down the strip.
