Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    I have had cars come to me for help...one for example AFR 195 headed 383...car seemed to run fine, no banging popping etc...but couldn't get up on the trans brake and felt lazy....swapped out his heat range 6 plugs for a set of 9s and the car picked up half a second at the track
    http://members.uia.net/pkelley2/sparkplugreading.html
    read that link and then check your plugs to see what the motor wants
    1994 Formula, 396cid, AFR 227's, Single plane, and 2 of the big ones.
    http://ltxtech.com/forums/image.php?type=sigpic&userid=241&dateline=12653889  02
  2. #22
    94 trans am
    chatsworth,GA
    Now you got me wondering. I look into swaping some plugs around and see how plugs looks. Ive run 7.0s in the 1/8 with these so far. I gota do some more reading on how to read plugs. I still got alot to learn. Thanks for the link.
    94 trans am forged 355, le 21* trickflows, le cam, a4 3800 stall
  3. #23
    Nov 2013
    Guillaume
    95 Caprice & 89 RX7
    Montreal, Qc
    Wow, I was using BR7EFS with the TT motor @ 18 psi and stock heads and was going to use the same heat range plugs with the new motor and AI ported TF heads...
    Guess I'll have to return the 7's and order a set of 9's to start with.
    1989 Mazda RX7 Turbo II, 357ci LT1, AI TFS CNC heads, Garrett GTX4708R, Ford 8.8" SAS, TH400. (Current project)
    1995 Chevy Caprice, Twin turbo 357ci LT1, 9.96 @ 141.2 mph (sold)
  4. #24
    I have a lot more experience tuning nitrous motors...I always start with a plug that I feel is 1-2 steps colder than what I will end up with on big power adder applications
