Results 11 to 15 of 15
Thread: Tuning shift points?
11-05-2014, 11:30 AM #11
- Oct 2014
- Jonathan
- 1994 Camaro Z28
- Delaware
- 19
I found this website here listed below for a base. Simple to use. Give you an idea what MPH to start with. I found rev limit in fuel cut off but not sure if that's right.
http://www.f-body.org/gears/
11-05-2014, 11:35 AM #12
11-06-2014, 08:36 AM #13
It usually takes mph and rpm to make the shift, start lowering both in small increments until you get your desired shift points. Check tranny fluid level too.
11-06-2014, 08:37 AM #14
How much til I get to see a difference?
5mph? 200rpm?
94 Camaro Z28 383ci AI Heads LE Cam 4L60E Stock 10 Bolt
Personal Best 10.72 N/A 10.13 NO2
11-06-2014, 08:37 AM #15
And thanks Moe!
