Results 1 to 4 of 4
    1994 Camaro Z28
    Orleans,IN
    Default stock axle question
    Are stock axles 28 spline? I'm planning on getting a mini spool and see there are options for 26 spline and 28 spline and even 30 spline. It is a 94 z28 by the way.
    1994 Camaro Z28
    Orleans,IN
    Also is the process that much more involved if I am taking a posi unit out instead of just the spider gears?
    LTXTech Sponsor
    Feb 2013
    1998 Trans Am
    Greenville, SC
    If you are going to do a mini-spool, your best bet would be to pick up a rear end from a v6 because I think you must have an open carrier to install a mini spool. I could be wrong though.
    1998 Bright Green Metallic Trans Am LS1/M6, Cam/Intake/Exhaust, Full Suspension, 3.42 gears, 30 MPG highway and 397 RWHP on untouched heads, 12.47@115 mph.... needs gears!
    2011 Victory Red Silverado 1500 Z71 LC9 5.3/A6, Z71 appearance package, factory 18's, e85 warrior
    Owner of Mickelson Performance, offering affordable LTX Tunes - mickelsonperformance@yahoo.com - www.facebook.com/mickelsonperformance
    1994 Camaro Z28
    Orleans,IN
    It looks like its the same setup minus having the plates with the springs and the clutches. It should be the same width across as an open carrier I would think. I'll have to do a little bit of research and see.
