Results 11 to 14 of 14
04-24-2013, 12:39 AM #11InActive Member
- Nov 2011
- Josh
- 1991 S-15 Jimmy SLE
- Decatur, Indiana
- 459
Just something to think about with thi, if you ever intend to race, but I'm pretty sure you can't have regulators or any fuel system component mounted to the firewall? I think is how I remember it. So if you run one inside they might fail it at inspection. I know it's not the firewall but its pretty close n even worse closer to the drivers seat.
nothin else just mount it like the judge did their tach n put a pod on the hood. Might look pretty nice if made to match the side view mirrors style I think.
1991 GMC S15 Jimmy- 1995 355 LTX- A4, almost AWD
1997 GMC Jimmy- 4.3 V6 - syty turbo setup
2012 Kia Rio5- wife's DD
1990 Acura Integra LS - DD
04-24-2013, 06:00 AM #12The FABRICATOR!
- Jul 2011
- 1985 Monte Carlo SS
- southern illinois
- 7,164
Eh, I'll keep the gauge around as a diagnostic tool but I'll put an AFR gauge in its place.
Now I just have to figure out if I want to keep that active hornets nest above the fireplace in the back seat.....Chris
04-24-2013, 06:42 AM #13
I wan't a wideband AFR too. Thinking I may sell off my collection of 2-5/8 autometers as they are a pita to fit in the 4th jenns.
04-24-2013, 02:12 PM #14LTx Guru
- Online
- 2,332
Many years ago, I tried an AutoMeter high pressure (100psi) fuel isolator, with a mechanical gauge. The isolator failed, and I found fuel in the glycol filled line inside the passenger compartment. When I complained to AutoMeter they indicated they had a problem with the isolators failing, and had discontinued them (I see they now sell one rated at 200psi). They gave me a full credit for the cost of the isolator and some -AN fittings I had purchased, and I applied the credit to an AutoMeter Sport-Comp electronic analog gauge. When we were modifying the fuel rails for parallel flow rather than series flow, the shop added a 1/8"NPT bung to one of the rails so we could mount the pressure sensor.
I would never use an isolator again.
FPRSens.jpgTahInst.jpgSOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
