    Default LT1 Metling Cats with CC503
    The engine is: 355, Dart Heads, Long tubes, Comp Cams 503 (224/230 112), 11.0:1 CR.
    At idle after a minute or so the cats start to get hot enought o begin to glow. My suspision is the overlap in the cam is pumping air and fuel out of the
    chamber and is combusting at the cats?
    I did not think this is a wild enough cams to have this sort of problem, so something is definetly off. I cannot seem to cut the fuel at idle enough with LT1 edit either.
    I had a scanner on the car and at idle I seem to to register misfire counts on cylinder 1 and 2. Not sure if it is actually a misfure at idle or the choppy cam causing an
    eratic crank speed at lower RPM. As soon as you come off idle, there misfire counts go to zero for all clyinders.
    Am I missing something in the tune? or something mecanically? I tried reducing the timing at idle to possible make the 02 see a rich mixture and cut fuel, but that did not seem to work either.
    If anyone would like any other information about the tune to bring this into context, please let me know, need to do something before car melts.
    3.4L to LT1 Swapper
    Oct 2008
    Brian Meissen
    1994 Camaro "Red Alert"; 2022 Camaro LT1 RS
    New Haven, MI
    I have a 357, stock heads, cc503 build also. My tuner put the idle tune at like 18:1 and said "it's OK, you don't have cats..." So maybe the idle is too lean, not rich.
    - Brian Meissen -
    "Magic Man" - LTxTech
    Owner - Michigan FBody Association
    1994 Chevrolet Camaro "Red Alert" [ LT1 Transplant ]
    2022 Chevrolet Camaro LT1 RS "Cherry Bomb 6.2"
    Thanks for the reply, if that were the case, how would you change that with LT1 edit?
    Jul 2012
    SouthWest Minnesota
    correct if I am wrong but if the cats are getting that hot is because it is burning up the fuel that is in the system. So I would say you are running rich. If your software tells you what the A/R is I dont know, or else you can use a wideband o2.
    I have 224/230 but it isnt the 503 but a custom boost grind. But pm me your email and I can send you my tune to use it as a comparison tool. I have it tuned for NA atm so it might give you some idea where to go with it.
    97 Comp T/A #161 out of 164 LT1 383 stroker, TPIS/AFR heads, JE pistons, 9.3cr, extreme energy comp cams 224/230, Howards billet rods 5.85, Callies dragon slayer crank, 2 bolt mains converted to 4 bolt billet, Mildon oil pump, MSD opti, 6AL, boost retard, HVC 2 blaster coil, BBk 58mm, 50lb injectors, 3200 stall. Took 600b off to help fund twin turbo.
    Jan 2010
    Louisville, Ky
    Are they stopped up?
    Bryan
    1994 B4C "Special Service" Camaro - Stock LT1 - 6 speed - 46k miles - Madz28 Tune - 307/340 sae
    LT4 Clutch - Delteq Ignition - K&N CAI - Pacesetter LT Headers - Magnaflow Exhaust - Unbalanced Engineering/Koni Suspension
    LS1 Brakes/Drive Shaft - T2R Diff - 373's - much more...
    Based on my understanding I would agree there is combustion at the cat.
    What is really confusing if the source of the fuel at idle that would be causing such a rich condition to have enough excess fuel to make the converters flow? My thinking was the overlap in the cam was
    allowing the fuel to pass though and hit the cat?
    The topic of the plugged cats came up, maybe they need to be cut-out, however we holding off on that as they are new. The exhaust system was just made up? Still a possibility.
    Thanks for the help bigtoyz, i'll pm you. Maybe I am missing something in LT edit.
    Thanks,
    Vic
    Jul 2012
    SouthWest Minnesota
    No problem just give a yell, glad to help out. I know when I rebuilt my 88 t-bird turbo coupe the timing was off and really raised hell on the cats. Just thinking out loud here, to give
    yeah idea's.
