Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    Jul 2010
    Alabama
    That's it lol. Doesn't it have reverse to the left and down or something like that? I remember its different from a t56. Also could that tranny be used in a fbody?
    Prev: 94 Formula V8 M6 - R.I.P. / 96 Trans Am WS6 M6 - Sold / 00 Firebird 3.8 M5 - Sold
    Current: 94 Camaro Z28 A4
    Jesse
  2. #22
    Quote Originally Posted by coolman1973 View Post
    What is different about the 93 tranny? Also what else should I be concerned about on a 1993? The car has 177k miles, has a Flowmaster and K&N FIPK on it. I got the car for $1800 with new tires, new computer(dealer installed), new brakes, and a new alt. Now the bad part-it won't start! ? Owner said the injectors are bad, but I don't hear the fuel pump come on. Still tinkering with it at this point. Thanks for all the responses.
    I just took off a set of stock injectors from my car, ill let them go CHEAP if you want em.. like $30 shipped..
    Also if theres one word of advice i can give,Its BUILD THE CAR FROM THE BACK FORWARD. Start with the rear end.. if i could go back i would be buying a 12 bolt or a 9in as my first upgrade.
    Sent from my DROID Pro using Tapatalk 2
  3. #23
    Don't forget the 91 and 92 Firehawks got a ZF6 Trans from SLP! So technically it's been in an f-body. Good luck finding one though.
    Oh and I remembered one other 93 LT1 specific item. 93s had 22lb injectors and 94+ had 24lb injectors.
  4. #24
    Oct 2008
    las vegas
    Quote Originally Posted by 93M6Formula View Post
    The 91-92 Firehawks did receive the ZF 6speed however the transmission tunnel was modified extensively to fit the bulky ZF and it had a custom center console to fit properly and it had a custom tranny crossmember fabricated.
    http://www.highperformancepontiac.co...k/viewall.html
  5. #25
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    Funny thing is that in the 93 tune the injector constant is actually set for 24#.
    Forgot about the early Hawks getting the ZF.
    Posted from my Rooted and ICS'd Rezound
  6. #26
    Jul 2012
    Kingsport,Tn
    Thanks for all the info guys. I looked on my codes and mine has the M29, sounds like the better of the two. I have a buddy with a set of Accell Injectors for Tuned Port Camaro that I can get cheap, will these work? He also has the Throttle Body to go with them, but I am pretty sure it isn't compatible with an LT1.
  7. #27
    Jacksonville, FL
    Do your research on those injectors. ALOT of people have had bad experiences with those. I would look into another brand. Anything but those.
    1994 Camaro Z-28 M6
    LE 242/248 cam,Crower split ratio rockers,AI 23*Trick Flow heads,JetHot longtube headers,Borla exaust,ewp,pro5.0,hybrid TNT wet kit.
  8. #28
    Yeah I wouldn't use those injectors myself and technically the TPI throttle body will bolt up and function on a 93 LT1. The IAC valve on a 93 is the same as a TPI but the TPS sensor is different.but all that would require is the TPI sensor and plug then just match the wires. But that's just a waste so just get a 93 LT1 TB.
