    Apr 2011
    Ft. Campbell KY
    Default coolant temp gauge problem
    I searched mulitple forums and didnt really find an answer so i will try this I replaced the sensor in the head and it stll not reading anything needle doest even flinch all other gauges work fine is there a fuse for this gauge ( Im hoping) that I missed or should i replace the pigtail or get an aftermarket gauge? thanks in advance for any help
    Mar 2010
    Ft. Lauderdale, Florida
    Have you tried tracing the wires from the sensor? I know its a pain to open up all the wire loom, but the wiring for that sensor runs awfully close to the headers and the block. There is no separate fuse for the temp gauge...if it were a fuse, other gauges/devices would not be functioning.
    1995 Camaro Z28 M6...383 cid, 4 bolt splayed mains, CP -6.83 cc pistons, Callies Compstar Rods, Callies Dragonslayer Crank, LE ported TFS 21* heads, LE Custom grind, 12.7:1 SCR - 452hp/440tq
    Nov 2010
    SoFla
    Yeap, First way to decide if there is a wring problem or if the gauge cluster has malfunctioned is to check the wire. An easier less time consuming way to check is to disconnect the sensor. Then find the pin on the PCM harness and test for continuity between the two. If there is 0 ohms of resistance and continuity then the wiring from the sensor to the PCM is good.
    Visit: shbox.com for wiring diagrams.
    95 Impala SS Clone
    Apr 2011
    Ft. Campbell KY
    holy shit Ive never looked at a wiring diagram before its confusing as hell but im going to see if I can figure this out thanks for the advice
    Apr 2011
    Ft. Campbell KY
    Well it didnt take much open of the loom before I found a burnt/frayed spot in the wire so can I just cut out that section and put a connector on there to reconnect?
    Feb 2011
    Chesapeake, Va
    The simplest way to check if its the guage or the sensor is to remove the plug/wire from the sensor and ground it. If the guage goes to MAX temp then the wire all the way to the guage is good, if that doesnt work then there is an open somewhere in the wire and the troubleshooting begins, so get your self a multi meter. If u need any advice i am an excellent trouble shooter, its what i do for a living, so just let me know.
    Feb 2011
    Chesapeake, Va
    Oh and a temp sensor is nothing but a variable resistor so grounding the wire out will give it max resistance.
