Results 1 to 4 of 4
03-25-2011, 01:20 PM #1
- Mar 2011
- Newport News
- 11
Running Power Wire for amp ????
For those that still have the Battery in the front of the car, and an amp in the rear. how did you run a power wire for the amp to teh battery? i have looked and looked and can not find a way to route the wire threw the firewall anywhere with out tearin the whole car apart. anyone have any ideas to help me out?
04-26-2011, 09:42 AM #2
- Apr 2011
- 7
Yes the passenger side behind the PCM is a gromet you can go through
04-26-2011, 01:58 PM #310 Second N/A Club
- Josh
- 96 Z28
- Holden, MO (KC)
- 2,867
^^ That's where I ran mine when I still had an amp and subs. Connected to the + post on the fender and through the grommet behind the pcm. You can then just use a screwdriver and pull the plastic trim next to the passenger seat and hide it behind that. Continue it all the way to the spare tire area!
As usual shbox FTW!
http://shbox.com/fw/Firewall_wire_feed.html
EDIT just noticed this thread is a little dated!!Last edited by 96LT1355Z28; 04-26-2011 at 02:02 PM.
-Josh
co-owner of BDBRacing.com
NMCA OC 9004
04-26-2011, 04:52 PM #4
- Mar 2011
- Newport News
- 11
hah, yes it is and i figured it out like the next day and got the wire ran. thanks for the extra input tho. maybe it will help someone else out.
