Thread: LT1 ENGINE PARTS GALORE
01-27-2011, 07:37 PM #1
LT1 ENGINE PARTS WILL SELL THESE PARTS FOR FAIR PRICE PLUS SHIPPING
PM FOR MORE INFO AND YOU CAN MAKE OFFERS
STOCK CRANK PISTONS RODS
LT1 OIL PAN
LT1 FRONT COVER 3 HOLE SMALL CENTER
LT1 FRONT COVER 3 HOLE LARGE CENTER
AIR PUMP BRACKET
LT1 BALANCER
LT1 WATER PUMP
LT1 WATER TEMP SENSOR
LT1 OIL COOLER ADAPTER
LT1 VALLEY SPIDER
LT1 STOCK CAM
LT1 OIL PAN NEW
LT1 OIL PAN SENSOR
LT1 OIL PAN BOLT SUPPORTS
LT1 VALVE COVERS
LT1 4L60E TRANS TUBE
LT1 COIL
LT1 CRANK HUB
LT1 EGR
LT1 P.S.PUMP
LT1 BELT TENTIONER
LT1 T.B STOCK
LT1 STEAM TUBE
LT1 OIL DIP STICK
LT1 OIL DIP TUBE
LT1 STEAM TUBE W/ FACTORY CRIMPED HOSE
LT1 PLUS WIRE GUILD {METAL}
LT1 A.I.R TUBE WITH SENSOR VALVE
LT1 FUEL RAILS
LT1 INJECTORS STOCK
LT1 ROCKERS STOCK
LT1 PUSH RODS STOCK
LT1 STOCK TIMING CHAIN
LT1 PAINTED BLACK LOW MILES INTAKE
LT1 STOCK INTAKE MANIFOLD WITH EVERYTHING
LT1 CUSTOM RED WATER PUMP COVER
LT1 ALT
LT1 REAR BLOCK CRANK HOUSING
LT1 T56 SLAVE
LT1 PRESSURE PLATE/FLY WHEEL
LT1 T56 CROSS MEMBER
LT1 4L60E TRANS CORE LOST 3-4
LT1 FLYWHEEL
LT1 TRANS DIP STICK
LT1 THROTTLE BRACKET
LT1 MANIFOLD PLASTIC VALVES EVAP SYSTEM
LT1 TPS SENSOR
LT1 VALVE COVER RUBBER INSERT {PVC}
LT1 VALVE COVER BOLTS
LT1 SPARK PLUG METAL COVERS SHEILDS
LT1 SPARK PLUG WIRE BRACKET LOOM
LT1 STEERING LINK
LT1 STEAM TUBE
LT1 OIL FILER WITH CAP
LT1 WATER NECK
LT1 CRANK BOLT
LT1 KNOCK SENSOR
LT1 WATER PUMP DRIVE SPLINE
LT1 AIT TEMP SENSOR
LT1 94 SPLINE DRIVE CAM
LT1 WATER PUMP DRIVE WITH BEARING
LT1 OIL FILTER ADAPTER
LT1 WATER LEVEL SENSOR FOR RAD
LT1 MAP SENSOR
LT1 INJECTORS
LT1 INJECTOR CLIPS
LT1 K MEMBER
LT1 LOWER MOTOR MOUNTS
LT1 OIL PRESSURE SENSOR W ELBOW
LT1 THERMO STAT
LT1 T.B. COVER
LT1 Y PIPE 95 NO CAT
LT1 EX MANIFOLDS
LT1 CRUSIE CONTROL TO INTAKE SUPPORT
01-28-2011, 07:42 AM #2
Can I get the steam tube, oil filter adapter, water pump spline, rear crank housing (for seal I'm guessing), valley spider, and water neck?
Is the throttle body cover the plate or the plastic cover for the cables?Last edited by Ryan Stout; 01-28-2011 at 07:45 AM.
01-28-2011, 12:35 PM #3
01-28-2011, 06:39 PM #4
01-29-2011, 04:03 PM #5
- Jan 2011
- 3
cant send a pm cause havnt made enuff posts. but im interested in purchasing the cam. please email me info... tylerrich19@gmail.com thanks
