Page 6 of 6 FirstFirst ... 23456
Results 51 to 55 of 55
  1. #51
    Big Papi
    2015 Fusion Titanium AWD
    Moscow Mills Mo
    Blog Entries
    1
    Go get a tune
  2. #52
    Jan 2009
    Paul Edwards
    1993 Camaro Z28
    Port Charlotte FL
    ok ill stop driving it till we get one. thanks!
    1995 Formula 383/t56 gone
    1993 Camaro Z28, forged, TFS heads, solid roller, prosystems carbed, t56 swapped spec 3+
    "Nitrous is like Tara Reid with an STD. You want to hit it, but your afraid of the consequences"
  3. #53
    Jan 2009
    Paul Edwards
    1993 Camaro Z28
    Port Charlotte FL
    heres Ion's responce thank you for having me contact him!
    Hi,
    Which engine harness are you using? If you are using a 94 harness, it is missing a wire for torque converter pulsewidth modulation.
    You can go to this link:
    http://shbox.com/1/harness_connector_faces.htm
    Then select 4L60E in the lower left corner. The PWM wire is in the "U" location. You will need to run this wire to the PCM's blue connector (D6):
    http://shbox.com/1/1995_pcm_conn_d.jpg
    I would suggest that you get a tune for your current setup before you try to troubleshoot issues. There are so many different variables involved with your setup that it is not worth trying to troubleshoot on a stock tune.
    Ion
  4. #54
    Watching and waiting.... very curious.
  5. #55
    Jan 2009
    Paul Edwards
    1993 Camaro Z28
    Port Charlotte FL
    im curious too. so i guess, fluid tune first then try the wire prong thing that i dont quite understand, me an wires dont get along. lol
