    Default i want true duals what parts do i need !!
    i want true duals what parts do i need please tell me and with prices so i can know how much to save up too
    Big Papi
    2015 Fusion Titanium AWD
    Moscow Mills Mo
    Blog Entries
    1
    They can be as cheap as 200 bucks all the way to expensive out the back. My personal set up that I have at home was 120 for the piping and the mufflers are going to be around 40 a piece for around 230 after I buy all the hardware and what not .
    I assume you have long tube headers already?
    i dont have long tubes headers
    my car bone stock and it in need of true duals bullet tips the ones that dump out before the axle right
    i dont want it to the back ima keep it cheap
    Big Papi
    Moscow Mills Mo
    Blog Entries
    1
    Going to need long tube headers. Then like I said it is up to the type of set up you want loud quiet , Dumped before the axle over the axle etc.
    okay im going to get long tube headers
    what else i hear x pipe or h pipe is there a difference between the 2
    Big Papi
    Moscow Mills Mo
    Blog Entries
    1
    They are different from exactly how they sound. I have noticed that most people get x pipes on ls1/lt1 cars
    This is what I personally have
    Hooker Super Comps
    3 inch Xpipe kit. No Mufflers yet
    and FYI there are at least two people on here selling long tubes in recent ads for damn good deals....
    out side the stl
    an h-pipe will give you a deaper tone and be able to tuck up more with a little more fab work. also depending on the torque arm setup and h-pipe might be your only option but you said you were stock so it doesn't matter to you.
    you could just get the summit or jegs universal 2.5" or 3"h-pipe or x-pipe kit, the mufflers of your choice (most use bullets for the most ground clearence).
    i usually will get a spare piece of pipe aswell. they come in 4 ft sections.
    i get the hangers from autozone as well as the turndowns.
    i have built probably 2 dozen setups using the above.
    1996 ss m6 white and black hardtop
    custom everything, cam, heads, 8.8 w/4.10s, duals you name it.
