Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Jan 2009
    Paul Edwards
    1993 Camaro Z28
    Port Charlotte FL
    Quote Originally Posted by Tarheel'Z' View Post
    i wanna say if the system is over charged it will not allow the compressor to come on either..i def could be wrong..id second the guages
    thats what im thinking too
    1995 Formula 383/t56 gone
    1993 Camaro Z28, forged, TFS heads, solid roller, prosystems carbed, t56 swapped spec 3+
    "Nitrous is like Tara Reid with an STD. You want to hit it, but your afraid of the consequences"
  2. #12
    Jun 2009
    Seneca SC
    Ill give you guys a little heads up from experience. If you have had the motor out of the car and have disconnected the main engine harness from the inside, that is most likely where your problem lies. On the passenger side behind the kick panel. There is 3 wiring harnesses that you disconnect to pull the motor out with harness and all. the little 2 wire connector back there is the AC switch. I was having to jump the relay until i discovered that it was not plugged back in. AC works like a champ now.
    1996 Cyclamen Trans AM A4
    GMPP Hotcam Powered 355 LT1
    All supporting Mods!
  3. #13
    Mine was different, after the car threw the code for the AC being low even now recharged it would not let it turn back on. After clearing it everything works great.
    Denny Crane /Rotary = Fail\
    LTx 355 w/ GM 847
  4. #14
    Jan 2009
    Paul Edwards
    1993 Camaro Z28
    Port Charlotte FL
    mpe331lx was able to find my problem thanks again phil!! it was behind the kick pannel i believe the high side switch? i guess i had disconnected it when i removed the heater core and forgot to plug it back in. thanks for the info though im sure that will help out other ppl. and woulda helped me too lol.
  5. #15
    Oct 2008
    1994 LT1 Camaro
    Port Charlotte, Florida
    Quote Originally Posted by 95formula383lt1 View Post
    BTW, it was the temp sensor that is in the evep box. It senses if the evap is freezing over and will turn off the compressor ontil the temp reaches a certain point. With it disconected, the compressore wont kick on.
    94 Camaro: 10.57@127, AI H/C, stock bottom, 150 n20, TH400, 8.8 rear (11.49@119 n/a T56)
    99 Z28 1SC Stripper: 5.3, S480, Th400, MWC 9"
  6. #16
    Jan 2009
    Paul Edwards
    1993 Camaro Z28
    Port Charlotte FL
    Quote Originally Posted by mpe331lx View Post
    yep lol i dont know anything about a/c except the basic stuff under the hood.... im still trying to learn!! but thanks again!
