Results 1 to 2 of 2
Thread: Idle bouncing
07-14-2017, 07:53 PM #1Xtreme Member
- Sep 2012
- Chris P. Bacon
- 1994 Firebird Formula
- Lansing MI
- 1,467
Idle bouncing
Hello all, I need help diagnosing a idle issue with my shitbird. I was cruising down the highway the other day and out of nowhere my tach started jumping. While cruising at about 1800rpms it was jumping up to about 3500rpms. The actual RPMs were not changing at all, and it responded to throttle like normal. I did pulls through 4th-5th and not didn't feel any misfires at all. Voltage seemed normal on the dummy gauge.
Here is a video of it at idle, it moves much less but still does it. I've checked all the battery (DEKA ETX18L) and they were tight, same on the alt. The alt had some power steering fluid on it so I cleaned that up but maybe the alt is hit?? Maybe the cluster is sad?
For those that don't know, the car is a 94 with a 5.3 swapped in. Up until Saturday is was completely normal, and I had been driving it about three hours without issue when it started.Last edited by Formula218; 07-14-2017 at 07:58 PM.
'94 Formula 6spd
07-14-2017, 07:58 PM #2Administrator
- 7,439
