Results 1 to 4 of 4
Thread: Gauge swap help
    Goliath
    Henderson, Nv
    Default Gauge swap help
    i have a 93 camaro z28, im trying to install 94-96 ta gauges.I have everything wired up,the only thing im having issues with is the voltage gauge,oil psi and coolant temp.Also the SES light wont lite up on its own and the check gauges wont lite up on its own.I can either get the oil psi to work or the coolant temp to work but i cant get them both to work at the same time.
    Ali
    '93 Z28 '08 Impala SS
    Quote Originally Posted by CamaroGirl View Post
    You don't like mustangs or ls1s.You're going to HELL you HATER.
    Quote Originally Posted by Tarheel'Z' View Post
    haha!! blubird is the biggest mustang hater ive ever seen lol give em hell Ali !!
    Oct 2008
    las vegas
    did you use the cluster plug from the bird dash and splice it to your camaro harness?
    what year is the cluster 94-97 i hope.
    Goliath
    Henderson, Nv
    yes,its from a 95 or 96 i believe
    Ali
    Oct 2008
    las vegas
    Ali i always forget you have a 93 you need a cluster for a 93 you will have problems until that is addressd.......unless you change to a 94 harness
