Page 94 of 95 FirstFirst ... 4484909192939495 LastLast
Results 931 to 940 of 947
  1. #931
    Online
    Definitely up in north Jersey near Newton. First name might have been Matt, last name maybe Italian origin. 23 years ago, and my memory is fading fast…..
  2. The Following User Says Thank You to Injuneer For This Post:
  3. #932
    these don't look tig welded
  5. #933
    New Nitrous Express Covert Crossbar showed up finally! gotta get the super vic to the machine shop to be milled for the plate and installed. Normally the jet fittings go out the rear, I will be having it flipped to front for access due to cowl.
    Gonna play musical fbodies tomorrow and possibly start pulling the intake off the bird tomorrow depending on how my back feels.
  6. The Following 4 Users Say Thank You to SSlowBoat For This Post:
  7. #934
    Found some fancy hydrodipped rad cover in someone's trash matches the black and silver theme for the bird, so the kids camaro will get the shiny one (hers is cut short for some reason idk why)
    otherwise no new updates. time has not been on my side on the weekends this winter
  8. The Following 4 Users Say Thank You to SSlowBoat For This Post:
  9. #935
    Nov 2011
    Marc
    1995 Formula
    magnolia, DE
    Dam, I was going to buy that off marketplace, but I thought it was a casket.
    Sent from my SM-S921U using Tapatalk
    1995 FORMULA M6
  10. The Following 2 Users Say Thank You to 95 blackbird For This Post:
  11. #936
    May crank the torpedo heater up tomorrow and get the vic jr off
  12. The Following User Says Thank You to SSlowBoat For This Post:
  13. #937
    Would you believe they are predicting a snow storm here on Tuesday????????????
  14. The Following User Says Thank You to JOATMON For This Post:
  15. #938
    it's insane, we are forecast for snow today and then super friggin cold, not looking forward to that
    machine shop said he should have intake finished this week
  16. The Following User Says Thank You to SSlowBoat For This Post:
  17. #939
    3-10in, very wild predictions
  18. The Following 2 Users Say Thank You to shownomercy For This Post:
  19. #940
    Wow, I just look at the NJ forecast -1 degrees Tuesday. Dats cooold. Many years ago, I lived and worked up North for about a year. After experiencing a blizzard and iced over roads, when I finished the project I tucked my tail between my legs and headed back South.
  20. The Following User Says Thank You to JOATMON For This Post:
