Results 1 to 6 of 6
    Sep 2010
    1995 TransAm 385
    Default M29 LT1 T56 Trade for MN6 T56
    I have a 93 M29 LT1 T56 for trade, looking to go back to an MN6 gearing. The gearing was great when was bolt-on and even with Stage 1 heads and mild cam, but now that I am running much more power with the AFR headed 385, I need a little less gearing. It has upgraded steel shift forks, billet keys, carbon synchros. Looking to trade for a comparable MN6 LT1 T56. Located in Jeffersonville, IN, just north of Louisville KY. Would like to trade within 2 hours but will also consider shipping.
    1995 TA M6 E85
    Power mods: AFR 210 Comp Eliminators, LE LT4 intake, Custom LE cam, 12.5:1 385ci, M29
    Suspension: Koni's, 600/175lb Ground Control, 36.5/21mm sway, Fays2 Watts Link, rod-ended everything, C5 brakes, etc.
    Jan 2018
    Kevin
    1995 caprice Wagon
    Hello - seeing this a bit late. I have an MN6 that I'd trade for this. It's a Stage 2 build from RPM Transmissions. I'm in Akron but will be travelling to Cincinnati in the next few weeks.
    Jan 2018
    Kevin
    1995 caprice Wagon
    BTW my trans has about 30,000 very easy miles on it since the rebuild. I drive like an old man.
    Sep 2010
    1995 TransAm 385
    Sounds good, sending you a PM with my info and we’ll meet up in Cincy
    Jan 2018
    Kevin
    1995 caprice Wagon
    I didn't get your PM, it may be because I'm too new. Might be easier to shoot me an email. ferrstein at hot mail (no 2 at the end of ferrstein). I will try to send you an email or PM but my post count is kinda low so that may be the issue.
    Jan 2018
    Kevin
    1995 caprice Wagon
    Yep. Just tried sending you a PM again and it doesn't show up in my sent items. I also don't see your PM. This board seems kinda glitchy, but I only signed up because I saw this thread on a google search. Anyway, shoot me an email at the above address to get hold of me. I'd like to discuss details.
