04-24-2016, 10:16 PM #1Lurker
- Gerald vargas
- 1997 z28 six speed
- Denver, Colorado
- 64
Question on cylinder compression cc503
So I have a used 100k lt-1 I slapped some ported heads on and a cc503 cam.
Wondering if my compression numbers are extremely low with this big cam?
Test was done on warm engine dry cylinders.
1# 140 psi
2# 137 psi
3# 136 psi
4# 140 psi
5# 150 psi
6# 140 psi
7# 140 psi
8# 145 psi
Thank you1993 Black Camaro Z28. Mod list: Aluminium Radiator.
04-25-2016, 07:30 PM #2
- Jul 2011
- 865
Is this on a 112lsa? Those seem low, IMO, but are at least consistent. Last time I did a compression test with a car that had a 306 it was in the 180 range I want to say?
04-25-2016, 09:14 PM #3Lurker
- Gerald vargas
- Denver, Colorado
- 64
Yes the 112 lsa
I wish mine was around 180.
I'm just wondering if my low numbers are really affecting the way it's running1993 Black Camaro Z28. Mod list: Aluminium Radiator.
04-30-2016, 12:30 PM #4Lurker
- Feb 2016
- George Harrell
- 1996 Chevy Impala SS
- North Carolina
- 14
This may be a dumb question but being at altitude does that affect cranking compression numbers?Did you degree the camshaft in?
Closet Mopar guy
04-30-2016, 02:03 PM #5LTx Guru
- 2,318
Good question. Atmospheric pressure at 6,000 feet is 11.8 psia (81 kPa), compared to 14.7 psia (101 kPa) at sea level. For any given compression ratio, the gauge pressure will be reduced as elevation increases.
And, test results will vary with engine temperature, battery strength, how far the throttle blades are open, number of crank revolutions, etc. That's why you look at the variation between the numbers to identify a problem cylinder, and generally ignore the absolute numbers.SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
05-01-2016, 07:30 AM #6
- Dec 2014
- john
- camaro
- 322
Not all guages are created equal either, I luckily bought a cheapo compression guage that reads everything I've tried it on within spec.
I though with the cylinder s so close it looked good to me.
05-09-2016, 03:14 PM #7Lurker
- Gerald vargas
- Denver, Colorado
- 64
Yeah that engine wasn't healthy. Threw in a forged bottom end lt-1 bored .30 over.
