Results 1 to 3 of 3
Thread: T56 swap?
    "Project Storm Trooper"
    Tony
    93 StormTrooper Z28
    Rapid City, SD
    Default T56 swap?
    does anyone have a template or measurements where to cut for the shifter?
    -Tony
    Official Member of $30k Club ​- Work in progress
    1993 Z28- 24x EFI, Clayton Racing 383ci, F1a w/FMIC, AFR 210's, LE Custom cam, LE LT4 Intake/heads, 80# injectors, 255lph/340lph pumps, T56 Conversion, 9" 4.11 w/spool, LPP LT w/Borla, Full UMI suspension....
    1987 Iroc-Z - Stock Summer DD
    Mar 2009
    Spring, TX
    Use the lower shift boot as a template. Once you put it on there, you can pretty much see how the boot should sit on the tunnel. The inner lip is where the hole ends.
    Jay
    1996 Camaro Zed28
    take a guess...
    ​jay
