Results 1 to 3 of 3
    Aug 2010
    Ohio
    Default Ticking when cold
    I'm trying to figure out the issue.... I'm thinking it is either valve train or an exhaust leak... When I start up cold and accelerate away I hear a steady ticking that follows rpm.
    I took the valve cover off. Wondering if the rockers are suppose to be this loose?
    Video
    http://static.photobucket.com/player...113_170333.mp4
    I tried to take a video of the ticking but I don't think it came out well....
    Video
    http://static.photobucket.com/player...113_170820.mp4
    Any help would be appreciated
    If it is just noise then I will live with it. Mainly I don't want to hurt the car so I want to find out the cause.
    Sent from my HTC ThunderBolt using Tapatalk
    Dec 2009
    Richlands, NC
    I use an EVAP smoke tester to find all kinds of leaks. Seal off one exhaust tip and fill the smoke into the other. i had an exhaust leak on my car and the rear bolt on the drivers side header had broken off in the head.
    1995 Z28 1997 SS S10
    Aug 2010
    Ohio
    well I shot gunned the problem and it seems to have worked. I adjusted the valves, flashed the stock fuel and spark tables, tightened the y pipe and manifold bolts, and changed the spark plugs. The tick is definitely less noticeable. Almost gone. I will have to wait for the engine to be stone cold before I will be able to see if my problem is completely gone or not.
