Thread: 4L60E question
11-01-2010, 05:56 PM #1
4L60E question
Ok my planned build should be around 400 to 425hp. Is there anything that I need to do to the trans? The car is an auto with the 4L60E.
11-17-2010, 06:34 AM #2
4L60E question
Shift kit
Forward sprag
Aluminum accumulator pistons
2-4 band (check rev input drum surface)
Replace 3-4 clutches with BW High Energy set
Vette servo (if not already equipped)
Deep trans pan
Auxiliary trans cooler
Make sure trans is free from ANY contaminants! Assemble (a little tighter than stock spec) & let 'er rip!
Sent from SuperSport's iPhone using Tapatalk
11-18-2010, 09:07 PM #3
What do you recommend as far as brands?
11-18-2010, 09:13 PM #4
11-22-2010, 10:13 PM #5
4L60E question
Transgo for the shift kit
Borg Warner for the clutches & sprag
