Results 1 to 5 of 5
Thread: Timing cover double roller???
07-20-2024, 03:51 PM #1LTX Master
- Jun 2013
- Beaver
- 1994 camaro Z28
- KENTUCKY
- 602
Do they make a timing cover to fit 94 z28 so I can use a double roller chain? Or eo they make the bottom of a 2 piece cover so I can use it
BEAVER
The Following User Says Thank You to beaver50 For This Post:
07-20-2024, 08:07 PM #2Administrator
- 7,346
Supporting Memberefi connection makes one that clears. a good single roller will suffice though
Sent from my SM-S908U using Tapatalk2021 Charger Scat 392
07-21-2024, 11:26 AM #3Xtreme Member
- Apr 2012
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,902
As someone who wasted money on an EFI cover and a double roller, I think you're better off running a single true roller set under a stock cover. The CLOYES 93651X3 is effectively the same as the LT4 extreme duty set but for less than half the price.
07-22-2024, 05:31 PM #4
Pretty sure that wont work on a 94! they are spline drive off the top gear unless you change covers to a pin drive opti.
07-22-2024, 06:26 PM #5Administrator
- 7,346
