Results 1 to 4 of 4
    Oct 2014
    Justin
    1995 Formula
    Houston, TX
    Default Which MAF with 24x?
    My upcoming build if going to max out the stock MAF. Since I'm going EFI Connection 24x, I'm considering upgrading to either an 85mm, LS3 card style, or the redesigned stock replacement. The card style would drop right in if I use a 3.5in pipe but if I go 85mm, I'll have to do something else with my intake. What do yall suggest?
    95 Cyber Grey Formula
    396 M6
    LE 244/252 .636/.636 110
    LE 215cc Trickflows
    1995 Firebird
    Western MA
    I run the LS3 card style in one of my builds.
    1995 TA: Converted Nose...381 LT1...4L80E...Moser 12 bolt...Edge TC...
    Best 1/4 10.71 @126, 1.46 60ft, 3450lbs
    http://www.youtube.com/user/MysteryBird1?feature=watch
    Oct 2014
    Justin
    1995 Formula
    Houston, TX
    Why did you switch?
    396 M6
    LE 215cc Trickflows
    1995 Firebird
    Western MA
    Quote Originally Posted by ElkySS View Post
    Why did you switch?
    It's what I started with.
