Results 1 to 3 of 3
01-27-2017, 05:46 PM #1
SOLD Lt1/4 GM "Self-Aligning" Aluminum Roller Rocker Arm Set (1.6:1 Ratio)- Set of 16
Decided to go a different direction. Selling my Chevrolet Performance 19210729 - GM "Self-Aligning" Aluminum Roller Rocker Arm Set (1.6:1 Ratio)- Set of 16, with locks.
$225
GM Description
These small block 1.6:1 ratio aluminum rockers are similar to the rockers used in the 1996 Corvette LT4 engine, except the trunnions have been machined for early model 3/8" rocker studs. These kits of 16 rockers include nuts and instruction sheets. They are self-aligning style rockers with washers between the rollers and the rocker body for improved wear characteristics. Reducing the length of the rocker stud slots improves the stiffness by 30% over comparable aftermarket designs. These rockers will accommodate up to .575" valve lift. One of the main advantages of these rockers is about 2 lbs-ft in rotation torque which provides a quieter idle. When using a high lift camshaft, be sure to check for valve spring coil blind, retainer to seal clearance, and piston to valve clearance. When using valve covers with drippers, it may be necessary to remove them for proper rocker arm clearance. When using on cast iron head check for adequate pushrod clearance.Last edited by steveh; 02-09-2017 at 10:03 AM.
02-09-2017, 10:03 AM #2
02-10-2017, 07:46 PM #3"The Rock"
