How do I go about painting the alternator without making a pretty paperweight? Its coming off tomorrow, so Id like to clean it up a bit. Any suggestions?
I took mine a part. It was easier than trying to mask off and keep the paint out of the internals. Reassembly is not quite the task you might think. If you pull it a a part, you will need a piece of wire to hold the brushes in place to reassemble. I used a 4" piece #12 ground wire.
http://uploads.tapatalk-cdn.com/2016...e56ff97b62.jpghttp://uploads.tapatalk-cdn.com/2016...9c3fbaa319.jpghttp://uploads.tapatalk-cdn.com/2016...f9c56ae506.jpg
I tried to add some pictures of mine. Not sure if they'll come in right, if not, I could email them to you if you're interested.
http://uploads.tapatalk-cdn.com/2016...a0da33c6ce.jpg
This should be the picture of the alternator guts. I'm not trying to scare you, I'm just not very organized.
Does the pack of Marlboro somehow help with voltage regulation? And the tape measure....does it have to be 3p ft?
I keed I keed.
Good eye! In all my mess you spotted my secret ingredient.
Thanks for all of those detailed pics. I'm just hesitant to take it apart since it's also my daily
Sent from my LG-D850 using Tapatalk
I understand you not wanting the risk of ruining a working alternator, maybe you might try something like a brush-on caliper paint instead of rattle can. Good luck with your project!
Relocate alternator so you don't have to see it :D
I've been thinking of painting mine too, because it looks corroded and ugly. These videos taught me a lot. They don't explain how to take off the pulley, fan, and rotor, but I think it simply comes apart when the nut on the pulley is taken off.
Watch "Part 1 - GM's CS144 Alternator Rebuilding, Alternator Repair. Visit www.AlternatorParts.com" on YouTube
https://youtu.be/LdFA6WF8lVg
Watch "Part 2 - GM's CS144 Alternator Rebuilding, Alternator Repair" on YouTube
https://youtu.be/vKbX7mezuFM
Those videos will probably help. The pulley and fan do come off when you remove the nut. That I remember, there is a bearing behind the fan that stays on the outside of the case. The rotor slides straight out but as soon as you remove it, the springs that are behind the brushes will pop out. That's why you'll need a piece off wire to hold them in place for re-installing the rotor. Everything else inside just un-bolts. Pretty straight forward. Just take your time.
I sanded mine to a smooth finish then painted. You could instead.
