Ok, so I am finally posting a build thread for my car. It is a 94 z/28 Camaro m6 that I bought in November 2012 for $1500. The guy i bought it off said he had blown the original motor and swapped in a lt1 out of an 95 impalla ss and hadnt driven it much after the swap. so i test drove it a bunch and decided to buy it as a project. well halfway home the motor started to develop a ticking noise. i got it home and started trying to diagnose what the noise was as well as doing the usual tune up items and fluid changes. i did a valve adjustment and that seemed to get rid of the noise for the most part. then it started eating through belts like crazy the more i drove it and i figured out that the harmonic balancer was sticking out about a half inch further that the accessories causing the belt to get kicked off. i did some research and found that the crank hub on an impalla pushes the balancer out farther than the f-body hub does. the car already had a K&N intake, edelbrock shorties, magnaflow cat back and a stage 2 ebay clutch. the plan for the car is to be a weekend toy and i want to get into autocross/roadracing with it at some point as well. it will rarely see the dragstrip at all as it will be setup for handling, but it would be fun to see what it runs though.
i will try to bring it up to the present state, but here are some pics of the car when i first got it home
http://i1175.photobucket.com/albums/...ps17eba0e4.jpg
http://i1175.photobucket.com/albums/...ps0e92b659.jpg
i decided to pull the motor over the winter and swap in a 383 ltx long block that was built by golen engines here in NH. here are some pics of the
teardown and removal of the motor
http://i1175.photobucket.com/albums/...ps34306e01.jpg
http://i1175.photobucket.com/albums/...ps30830317.jpg
http://i1175.photobucket.com/albums/...pseaa25b19.jpg
http://i1175.photobucket.com/albums/...ps3c87c106.jpg
motors out!
http://i1175.photobucket.com/albums/...ps8ba6bf22.jpg
http://i1175.photobucket.com/albums/...psa5324fe5.jpg
heads/intake off
http://i1175.photobucket.com/albums/...ps70f6ce04.jpg
the new motor has the stock aluminum heads and intake that have been ported and have new springs/valves installed, a cast scat crank, with scat forged i-beam rods and wiseco forged pistons at 9.5:1 compression, along with comp 1.6rr and a custom comp cam (214/224, 555/568, lsa 115). i plan on putting a d1sc @8lbs on it at some point but for now will be running it n/a while i build the drive train and suspension to support that.
http://i1175.photobucket.com/albums/...psd8a3ee61.jpg
http://i1175.photobucket.com/albums/...ps8921bddc.jpg
then i assembled the new front end which consists of a BMR tubular k-member, upper and lower adjustable a-arms, and a set of double adjustable viking coilovers with the 550lb springs. i blasted and painted the upper mount and spindles and put new timken hubs on
http://i1175.photobucket.com/albums/...ps1d1dad1b.jpg
http://i1175.photobucket.com/albums/...ps67460742.jpg
trans bolted back up. i decided to put the ebay clutch back on since it was brand new and i figured i would give it a try since i have it
http://i1175.photobucket.com/albums/...ps7d9bb99e.jpg
pacesetter longtubes installed, much easier than doing it when the motor is in the car as well as a BMR trans crossmember with torque arm mount and a hust shifter
http://i1175.photobucket.com/albums/...ps3ec79497.jpg
http://i1175.photobucket.com/albums/...psc99cebd7.jpg
lowering the car onto the subframe
http://i1175.photobucket.com/albums/...ps968ad684.jpg
aaand its in!
http://i1175.photobucket.com/albums/...ps2f9d2ad1.jpg
http://i1175.photobucket.com/albums/...pse11168ac.jpg
http://i1175.photobucket.com/albums/...psc4ad8f0d.jpg
this is my brake setup: stock, repainted calipers with EBC redstuff pads and rotors. i will be getting the same setup for the rear as well. when these wear out i will look into a big brake setup, but for now this will do just fine.
http://i1175.photobucket.com/albums/...psd20a9785.jpg
i have the radiator and fans reinstalled, BBK 58mm TB installed, brake lines hooked back up (need to bleed them), tick master installed (need to bleed), i have the viking rear coilover kit with 150lb springs from UMI on the way, BMR adjustable panhard bar installed and a set of their adj lower control arms waiting to go on, strano hollow sways, a set of bosch 42lb injectors, and the drive shaft is in. that brings it up to the present.
let me know what you guys think or if you have any suggestions!
