Originally Posted by
Injuneer
With stock programming, the first fan (or both fans on low for “late 1994's) should come on at 226°F, second fan (or both on high) at 235°F. But with the 160°F t'stat, it’s normal to reduce the fan “on” temps, to get any benefit out of the 160°F t'stat. Did you wire the new fans same as the stock fans? Have the fan “on” temps been changed? Do you even control them with the PCM?
And running at 180°F with a 160°F t'stat isn’t unusual. A 160° t'stat only starts to open at 160°. Generally not fully open until about 180°.
Did you buy a standard pump, or a heavy duty (high flow) pump?
Did you wire the pump correctly - blue wire to +, black wire to ground?
And the mandatory LT1 question - did you fully bleed all air from the system?
