What valve springs u runnin
http://uploads.tapatalk-cdn.com/2016...ede95f6606.jpg
I was having a hard time finding a p71 crown vic driveshaft for a reasonable price so I can have it cut, specifically the mmc. I would've settled for regular aluminum, but the idiots online want mucho dinero because they say POLICE on them in big black letters. If I was going to overpay I'd just get a Denny's that doesn't need to be shortened, pfffffttttt. I scoured the yards earlier instead and came home with 3 aluminums for $75. Will still be on the lookout for the mmc in the future though but this will do for now.
Started pulling it apart
http://uploads.tapatalk-cdn.com/2016...6c54b1ed68.jpg
It would be a shame if...the fuel pump....
Haha kidding! I hope to see this thing on the dyno in the spring.
http://uploads.tapatalk-cdn.com/2016...7b53c71d00.jpg
I forgot how much I fucking hate GM ujoints with the nylon holding them in
http://uploads.tapatalk-cdn.com/2016...4b5d7f76ba.jpg
Front cam bearing looks a little toasty. I can't tell what the others look like bc I forgot my junky usb inspection camera. I'm gonna throw the cam in anyway though being that it only cost me $100. Motor still had good oil pressure so idk.
Dude, the lt1 front bearings always look like shit from the stress of the water pump drive. You shoulda seen my 230k mile motor when i slapped the hotcam in. Front bearing had a groove. Even the impala motor with 114k. Itll be fine
Spray some bronzer on that and its good to go.
Imma pretend I didnt see it...
Anyone want some headers? Lightly used, 200obo
http://uploads.tapatalk-cdn.com/2016...ddc55b689b.jpg
Picked up a rear sway bar, manual seat rail for the drivers side, and rubber floor at the yard yesterday. If someone pukes or takes a dump on my floor I'm totally covered now.
Might also be converting to rear disc brakes.
http://uploads.tapatalk-cdn.com/2016...69be7ea78f.jpg
http://uploads.tapatalk-cdn.com/2016...57bd31f99a.jpg
Also, newly shortened driveshaft courtesy of Hartman Driveshaft in Reading.
http://uploads.tapatalk-cdn.com/2016...e2cc28805d.jpg
Hey man... i know u said u were interested in my ss springs. I just wanted to make sure u knew that I had cut half a coil out of the fronts.
http://uploads.tapatalk-cdn.com/2016...a08c79f86a.jpg
OWNER/ADMIN
I am going to be selling them but won't be cutting any deals though, trying to make some money back bc car is making me broke. Will probably throw them up on CL or ebay for $100ea and see what happens. And the shortening was $150. I gave him the wrong u-joints because the info on the impala forum was wrong and the ones he threw in were kinda pricey so the total cost went up $55~. Whole thing was $270 in all, not bad considering the Denny's/Inland Empire/PST are all $500+.
http://uploads.tapatalk-cdn.com/2016...7f702653dd.jpg
Fun fact about t56 swapped bbodies: You have to lift the motor this much after sliding everything forward to get the oil pan out... Gah
I would've but I lent out the trans jack and I'm working alone. Wrestling with the t56 is also a huge pain in the ass and I'm trying not to overexert myself (doc's orders). Doing what I can at a snails pace.
The springs I was thinking about are Moog 5664 or 7268.
Hopefully I won't go into a huge food coma and actually get some work done tonight. Swapped the oil pump spring and put the pump back on, just needs to be torqued along with some other bolts. Then the pan and timing cover gaskets will go on and I can finish cleaning the stock for the heads.
I picked up rear calipers, caliper brackets, and backing plates w/ebrake shoes at the yard for $45. I need to order ebrake cables, rotors, and pads to complete the disc conversion. This should save about 9lb per side and decrease unsprung weight a good bit.
I weighed the 9c1 rubber carpet and the difference between stock is only ~3lb. The rubber fits like crap so I'm going to sell it.
Mic'd some valves and found that the new stainless valves are generally 0.0002-3" larger in diameter on intakes and 0.0003-4" larger on exhausts. Couldn't get a good measurement for the inner diameter of the guides with crappy ball gauges, but the difference in valve size isn't big enough for me to worry/care.
Also measured the volume of the combustion chambers with the new valves at 51.5cc. Going to use stock replacement Fel-pro 9966PT head gaskets for SCR of 11:1 and craptastic quench. Not going crazy with comp or cam because car will hopefully double as a tow pig.
Pan and timing cover are on. Tomorrow I will continue cleaning the deck and hopefully get at least one head on so I can measure for pushrods. Will probably button up the motor and tackle the diff next weekend with some help, then the maiden voyage.
Movin right along man...
OWNER/ADMIN
http://uploads.tapatalk-cdn.com/2016...e0226e3a8e.jpg
OWNER/ADMIN
Got in over my head last time I worked on this and ultimately stopped due to health issues. All is well now and the dyno day/ocmd have passed so it's time to get the piggy rolling again. I started by cleaning the garage (somewhat). Getting ready to break down the diff, rebuild the yukon posi, and setup the new 4.56s. Then I need to hone the valve guides, put the top end on, put the front suspension back together with moog springs, fix steering, install new rear suspension bushings, sway bar, abs delete, new brake lines for the rear, rear disc conversion, etc. Looks like I have my work cut out for me this summer.Attachment 37719
I hope this will be my ride to oc in the fall.
Gutted the diff and tried scraping most of the grime off. I got it reasonably clean, it was filthy. New wheel bearings and races are in so I started working on reshimming the posi with the new spiders. I didn't notice this before, but one of metal alignment tabs for the clutch packs sheared. Guess I can't do anything with the diff until I source one from Yukon. Will move on to the heads.Attachment 37721Attachment 37722Attachment 37723Attachment 37724Attachment 37725
Remeasured the guides and valve stems on the le1s. The new stainless valves are rougly .0002-4" thicker across the board than the stockers so the guide clearance needed to be opened slightly. I did some light honing with a flex hone and got all clearances around 0.0011-14" but I will double check tomorrow and possibly open up some of the exhausts if needed. I also did some lapping but need to order a finer compound for a final pass. Once that's done I can finally assemble everything.Attachment 37727Attachment 37728Attachment 37729
Opinions on mufflers to replace the dynomax super turbos? Needs to be louder but not obnoxious like my camaro lol
get the porters I put on the impala from @popo8. he's going to switch it up i think
My $3 part and $7 box, thanks summitAttachment 37749
Just finished my last full time semester at school so I finally have time to work on this pile.
Got the posi back together with the new spider gears. I reshimmed the clutch packs as tight as I could without the spiders binding. Hopefully I won't have to reshim again. Getting the preload springs/plates back in was also a huge pain in the ass but the Yukon feels great now.
New bearings are in so tomorrow I'll set the backlash and run a contact pattern.Attachment 38122
Sent from my VS995 using Tapatalk
https://uploads.tapatalk-cdn.com/201...e0366da816.jpg
I'm a little rusty but I think I got it. Pattern looks decent and the backlash is at 8 thou.
Attachment 38123
Attachment 38124
Finished honing the guides, lapping seats, and cleaning the heads. Assembled them with Crane duals and fancy new Comp locators. Had to do a little grinding on the Comps to fit the spring pockets.
2 rocker studs and 7 guideplates are MIA so I have to go digging for them.Attachment 38130
