bout time for an update, and potentially not a good one at that as you'll see later. went on a little vacation last week for the 4th of July and before i went out of town i got a bunch of work done on the car. first off is a pic of my re-done turbo support bracket that i meant to put in a while ago when i finished it.
Attachment 38966
got the complete hotside final welded and made sure there weren't any pin holes or anything. i wasn't able to find anywhere that sold the POR15 "black velvet" that SNM was suggesting but ended up with high temp POR15 which is a gray color instead of the normal black. got the hotside completely coated and is ready for heat wrap (which i have)
Attachment 38967
Attachment 38968
Attachment 38969
Attachment 38970
pulled the water pump off and tapped a -10AN thread in the outlet that was hitting the turbo (oil cooler feed) and plugged it and got that reinstalled with new gaskets
Attachment 38975
i also dropped the subframe so i could finish weld the cuts i had to do for the manifolds to fit and drop the oil pan to weld a turbo drain fitting on and replace the low oil level sensor as the light was always on even though it had full oil. i had to cut off a corner of the passenger rear control arm mounts so i boxed that in and painted it and also cleaned up and painted where i had to clearance the driver side motor mount for the manifold. supported the motor with a jack under the front of the transmission
Attachment 38974
Attachment 38971
Attachment 38972
Attachment 38973
now we come to the bad part of this update...... pulled the oil pan this afternoon and found some stuff i am not to happy about. got the oil level sensor off and saw the reason why it was faulty..... not sure where the float is but it certainly isn't in the pan anywhere. old one next to the new one:
Attachment 38976
so that had me looking around in the pan for the pieces of the float and that's where i found this, looks like a needle bearing from something, thinking possibly roller rockers but not sure, i have comp ultra pro mags 1.6 ratio, not sure if they have needle bearings or not
Attachment 38977
that prompted me to look in the pickup screen and that's where it got interesting..... found several chunks of metal lodged in the pickup. not sure how well you can see in the pic
Attachment 38978
so needless to say i will probably be calling my engine builder Monday (or stop by and talk to him as his shop is 5 minutes from where i work) and see what he says. super bummed finding this stuff, everything looks good on the bottom end and the car ran great with no inclination that anything was wrong before i pulled it apart. i don't have the spare money right now to rebuild this motor if it needs to (most likely does) but i guess we will have to see what Golen says. let me know what you guys think, pretty much at a stand still. i was hoping to have the car back on the road by the end of this month but looking like it will be a while now :\
