Mounted top of radiator
https://i.imgur.com/xgzKzurl.jpg
I will be relacing em with nutcerts but, this is a proof of concept.
Big photo dump from the past week or so
Had to modify the radiator to get room for the air filter on turbo. Also added vac line port to elbow.
https://i.imgur.com/wHqgKPQl.jpg
No more coil of copper, proper backpressure damper cylinder
https://i.imgur.com/XnjmXC9l.jpg
Painful purchase but MLS gaskets are the best
https://i.imgur.com/ZZEuBPql.jpg
While I was waiting for heads, have been experimenting with manifold heat management
https://i.imgur.com/0wexbJ7l.jpg
And the heads, machine shop found some lovely gems from the previous owner of these heads
https://i.imgur.com/P82MzZtl.jpg
But both heads resurfaced, 0.007 off both to clean up
https://i.imgur.com/wc3ZGNMl.jpg
Its hard to see but the bolt/head stud holes were reamed out, and then sleeved so the port breakthru didn't suck oil down from top of head
https://i.imgur.com/PZX823Nl.jpg
Pretty sure every LT1 owner goes thru this picture at least once
https://i.imgur.com/RFp7geIl.jpg
Heads on, rockers & guides setup, intake bolted down
https://i.imgur.com/cqUPUVul.jpg
Looks great. You've been busy. Is the intake actually touching the cowl or optical illusion?
No cutting needed
https://i.imgur.com/p0imZPrl.jpg
I don't even have the hotside on yet lol
