How much fuel do you need?
YES
https://i.imgur.com/AoN0EsLl.jpg
Roughly 615lph
YES
Roughly 615lph
Yanked off the driver side header to check for flatness and or, look for stripped threads in head. Def had a leak at the cylidner I thouhgt I had stripped
https://i.imgur.com/bGTPWITl.jpg
Then started the new MSD wires, got lent this fancy tool
https://i.imgur.com/poZ8neXl.jpg
Out with the old wires
https://i.imgur.com/aEYiF5Fl.jpg
New coil side in car
https://i.imgur.com/NM0oflkl.jpg
New wires on engine side
https://i.imgur.com/ZPuEoCMl.jpg
Header will go to a machine shop over the week and hopefully that fixes the leak at cold idle.
Slow progress towards dyno day.
Finished up the passenger side, and finally sat down to test the reistance off the wires.
This was a bad one
https://i.imgur.com/jX4cUTpl.jpg
Ended up cutting two ends off to get readings
https://i.imgur.com/XOdNTIfl.jpg
So, it seems I had been running around with a V6
https://i.imgur.com/3AW3lVml.jpg
Not sure I trust these numbers, but, if so, thats a lot of power/fuel being wasted.
And, flange is flat. Local machine shop did it for $75, which I thought wasn't terrible for flycutting it vs the ole belt sander.
https://i.imgur.com/gngokqfl.jpg
Successful day back in the garage.
Tremec app measured the driveline angles just wanted to be sure I am good to go
https://i.imgur.com/3NsPTzTl.png
Fuel Temp sensor stuck in regulator
https://i.imgur.com/yx8tC7wl.jpg
And took it around town, took forever to get oil and coolant up to temp. Darn winter.
https://i.imgur.com/TdySbkOl.jpg
Very clean, and nice looking! Maybe you covered this somewhere else, but are there turn signal indicators on that screen?
Yup, that red dot on the right side is turn signal. It blinks like factory would.
Because moar data is always good. Now I can have proof that my turbo is way to small for the motor :bertstare:
http://i.imgur.com/gFuvJYrl.jpg
http://i.imgur.com/UJasAVyl.jpg
http://i.imgur.com/kLe3ycXl.jpg
Finally got around to finishing this side project up. ABS sensor repurposed to a speed sensor. After dyno is done, I can now play with traction control based off comparing front wheel speed to VSS signal and pulling timing based on slip.
https://scontent-iad3-1.xx.fbcdn.net...d3&oe=60673934
