Im getting ready to wire up a new gauge pod and am wanting to use the stock sending units instead of adding new ones deleting the stock gauges. Is there a write up showing which wires to tap into? This is for a water temp and oil pressure gauge.
bump!! i need this also :)
Just from quick glance, this might be what you need. I'm no wiring expert, but maybe it could help?
http://shbox.com/1/harness_connector_faces.htm
