Will 15 inch rims fit on the back of a1997 Formula ws6 disc brake car?
what slick sizes can used 26x10.
Yes I do realize the rear might not like them.
Yes, a 15 will clear the rears.
IDK as far as drag radials, but out car can eat up a 315 easily with the correct back spacing.
Your 10 bolt ...
Attachment 38059
I put 15”x10” Weld Pro-Stars on the rear (WS6 brakes are no different than any other V8 model) and I had to grind down the fins on the caliper.... no big deal, but required with the Welds.
Do you want a true "slick" (like an ET Drag), or a DOT slick? A 26x10 tire needs a 10” wide wheel, although some tire manufacturers will say 8” to 10” wheel. 15x10” will need a 7.5” backspace to keep the wheel/tire under the car. 15x8” wheel will work with 5.5” backspace.
I ran a Hoosier Quick Time Pro DOT slick, 28x11.5-15 on the 15x10 Welds with no problems - see signature photo. Inner fenders had already been hammered for my 315 Street tire’s though. A 26x10.5-15 is no problem.
I ran a 275/60/15 micky pro radial now i run a 26x10.5-15 micky stiff wall slick and they both fit great with a stock offset wheel
Attachment 38060
Looking good Shadow! What kind of 60ft can you get.
i have never taken it to the track only grude race the car it 60fts i think 1.5 60ft
29x10x15 over here
