Fuel pump went out. going to drop the rear and build it up. I have a few questions?
So I'm going to drop the rear (because fuel pump went out and I don't want to do any cutting) and build the 10 bolt slightly. I have a new t/a rear cover to put on. But my question is.... I want to weld my axle tubes. What's the best way to do this. Drain the fluids, grind the metal to get a clean weld, then weld? Can I do it this way? Or could the rear end get to hot welding then I would have to replace seals of some sort? I'm not sure. Kind of new to this. Any advice would be great.
thanks so much!
