High idle LTFTs, good otherwise
So I'm working on my tune for my hotcam and my LTFTs driving around and cruising are ok- ranging from around 125-132. Mostly right at or near 128. My LTFTs at idle shoot straight to 160. The STFTs are in the 140s at idle too. I've checked for vacuum leaks, fixed a couple exhaust leaks, and replaced a failed O2 sensor so far.
It smells like it's running real rich at idle too, just like my stock tune did before the cam swap.
I'm finding conflicting information regarding fuel tuning. I'm seeing people say to adjust the VE tables, and others saying that'll do nothing. Everything in my fuel system is stock and I'm running a K&N CAI, LPP long tubes, Magnaflow cat back with the hotcam and 1.6rr. Where do I need to go to get my idle fuel trims back in line? I can post a scan 94/95 log later if needed.
Thanks in advance.
Sent from my SM-N920T using Tapatalk
