Main studs spin when loose? & Clock the Cam Bearings?
Hey all, I've currently got the crank rods and pistons assembled. When we were plastigauging the crank everytime I would take all the nuts back off of the ARP Main Studs I purchased the studs would spin as well as the nuts. The ARP instructions say to just hand tighten them in to the block, and when it's torqued to 80ft lbs of course they aren't spinning. Just wondering if that's common.
Next, My father read somewhere on a forum and in a book about LT's that you're supposed to clock the cam bearings. Instead of aligning the cam bearings with the oil feed holes, you position them at 5 o clock and the main is at a different position, but not aligned with the oil feed hole. It's supposed to keep oil pressure up during high RPM? True or False?
As my engine is, the crank spun freely when torqued. The cam bearings were aligned, but then we took em out and put em back in with the 5 oclock position. Same bearings used.
